These were done in 5/4 solid cherry with dovetailed corners. Dovetailed corners on cabinet sides, top and bottom deck were cut with separate files using a 1/4" endmill. Slight sanding done on the tenons (fingers) to compensate for the inside radius caused by the bit on the mortised side. Sanded to 800 grit and then 2 coats of hand rubbed varnish. SO SMOOTH Any questions, be sure to email.....JR
http://i36.photobucket.com/albums/e1...entpics049.jpg
http://i36.photobucket.com/albums/e1...entpics054.jpg
